I see you use a TUneEcu software.
I've just bought 16pin usb cable and 6-pin ktm plug.
I also downloaded all Tuneecu soft.
Can you check something in your cable because I need to confirm it...
Please see the FIG 1 picture on: KTM_Components
because the 16pin cable I received has a male-type plugs where on the picture is female... Also in my cable the pin numbers are different...
In my cable pin number 16 is on the other end than the one on the picture...also pin 1 is on the opposite side.
Can you check how it is in your ?
This is important for me because pin 16 is a 12V connector so if I do something wrong then I can damage ecu.
Can you tell me how to check current TPS values so I can know is it ok or not and if not how to set correct values ?
All that operation must be done on cold engine and when the engine is turned off so just turn a key into ignition position ? am I right ?
do I need to touch a throttle ?
LinkBack URL
About LinkBacks
