good evening all, when i start my bike then let choke off i blip throttle she cuts out, any clues pls![]()
paul
most big singles will do that,....
surreysupermotos.co.uk
"Alcohol Free Lager . . . . . . . . . . . . . . . . . it's like licking your sister's fanny. It tastes the same but it's just not right."
" Internet fights are like the special olympics - even if you win, you still looked retarded. "
raise the tickover job done
DCR SUPERMOTO TEAM...
should let it warm up before you start revving it - yer mota will last longer dude![]()
06 560 SMR
1050 Speed Triple
sxv 550
you just cant trust some garages
after youve chocked the mrs dont you have to give her chance to recover?![]()
Slippery toys
04 660 SMC
03 501 Husaberg
06 290 Sherco (Intermediate)
Castle Colchester MCC Ltd
As above, that is normal, let it warm up a bit first, ie, start it, put lid on, put gloves on drive off and keep the revs down for the first few miles.
normal, don't blip it until it's warm, you have to be smooth while they are warming up
thanks all i dont like revving to high till she`s warm so i`m doing right for a change ta
paul
By the way -----
Even when warm and the idle set correctly.....most carbs will have the 'dredded' off-idle bog. This is what the accelerator pump is for --- and the bog won't go away until you have the jetting and accelerator pump set correctly.
Installing the James Dean (JD Jet Kit) Jet Kit made a HUGE difference with this. (this kit comes with a small o-ring that goes around the accelerator pump linkage --- thus reducing some of this off-idle bog) I also just went the extra mile and installed a R&D Power PUMP - on the fly adjustable accelerator pump......
BTW--- I have the 625 SMC w/ the Keihin FCR-MX 41 carb.
Got to warm them up before they swallow the juice,worth the wait .
