Kit is now available in UK, 2 kits one complete with full Akra, other is camshaft, K&N and fitting kit.
Anyone in the know as to what gains will be over EVO 1
Corners are key, anyone can ride fast in a straight line
2011 KTM 690 SMC
2007 BMW GS1200 Adventure
2005 Harley Davidson Screaming Eagle Fatboy
2002 Yamaha R1
2000 Yamaha R1
1997 Kawasaki ZX9
1989 Honda CR250
1988 KTM 495
1986 Honda CR250
1982 Kawasaki KDX 175
06 450SMR Money burner
08 690SMC Seller
07 990SD Divorcee
05 950SM Crasher
Thanks Etuna, but thats from the USA.
2011 KTM 690 SMC
2002 Yamaha R1
2000 Yamaha R1
1997 Kawasaki ZX9
1989 Honda CR250
1988 KTM 495
1986 Honda CR250
I reckon the gains in the USA are the same as the UK unless the timezones or exchange rate impacts it?
08 690SMC Seller
07 990SD Divorcee
05 950SM Crasher
feels just like you think it would.
little loss of grunt right off the bottom rpms, but feels more revvy, and hits harder up top.
you trade some low end torque for more hp and over-rev. instead of falling off a little at top revs, it pulls all the way to the limiter.
Again, I haven't yet been able to run it with a completely perfect map as I'm still working with Vortex on an updated fuel curve for the new cam. It will probably gain a little torque back once it gets dialed in because right now its running real rich down low and in the middle and a little lean up top.
Even with the fuel adjusters on the Vortex the curve is off because of the different nature of the cam profile. It needs opposite fuel curve form the standard cam (need lees fuel down low and more on top) Its the way the fuel needs to be ramped through the rpms that is the issue. You can add or remove fual all day, but unless you get the curve right then its not going to be perfect. All the Vortex maps right now are deigned around the stock cam profile.
As for the sound it is same loud, but instead of echoing and booming right in front of you the intake noise is behind and below you so it seems much less noisy.
Yeah, there is a part number on the filter. I can get it when I return from vacation. But K&N show it not available in the states. Also you WILL need to move your battery to make it fit. It needs all that space.
08 690SMC Seller
07 990SD Divorcee
05 950SM Crasher
But they do talk a load of bull mate
2011 KTM 690 SMC
2002 Yamaha R1
2000 Yamaha R1
1997 Kawasaki ZX9
1989 Honda CR250
1988 KTM 495
1986 Honda CR250
well I'm not gonna rush out and get one. See what sort of feedback it gets from the Uk market first.
2011 KTM 690 SMC
2002 Yamaha R1
2000 Yamaha R1
1997 Kawasaki ZX9
1989 Honda CR250
1988 KTM 495
1986 Honda CR250
Yeah cos all those Yankee doodle dandies are stoopid right?
On a less mentally generalistic note, seems like a lot of lira for loss of bottom end v increase in top end. I won't be bothering
08 690SMC Seller
07 990SD Divorcee
05 950SM Crasher
Exaggerate yes, having delt with them for many years on a professional basis. I just prefer to get my information from source.
No offence intended
2011 KTM 690 SMC
2002 Yamaha R1
2000 Yamaha R1
1997 Kawasaki ZX9
1989 Honda CR250
1988 KTM 495
1986 Honda CR250
