hi guys noob on this site,
I have 04 125 sx pretty much in mint condition but the other day I noticed a little pool of water lying under the bike I have traced the water back to a small hole on the very bottom of the engine right at the crank halves maybe hit a rock/stone, I don't know but it does look as if something has hit this area. I have stopped the leak by applying a little chemical metal on it job done. but I have been thinking how does water/coolant get to the very bottom of the engine is there suppose to be water here or do I have a internal water leak. there is no white mucus on oil filter cap, I do jet hose my bike after every blast but I have not been out in a week. Why did it leak water and not oil especially being at bottom of the engine the radiator was half empty I don't know how the coolant passages/veins work on these cant find a decent engine manual should I just take the chemy metal off due to water building up in engine now. could any one shine any light on this please.
I would at first clean the bike, then dry it, then run it whilst watching for a leak! water is funny comes from miles away and makes you think its from this crack etc. is the coolant in the rad going down? its not come from a hose, then dribbled down there and the traces of it getting there have evaporated?
good luck
good luck
thanks i will try put a dye through the coolant system then see where i go from there thanks for your reply mate.
The waterpump seals have gone. Dont bung up that hole, its designed to let the water out instead of it going into the gearbox!
So do a seal swap.
So do a seal swap.
haha your the the man i have just been told this info i now need to get the chemy metal
off what is the seal called??
