1 - 9 of 9 Posts
Checked clock is working so fuse can't be blown (I am assuming this is accessory socket ACC 1 / CLOCK & not ACC 2 as referred to in the users manual) ?
First noticed when no LED light up from Optimate charger when plugged in confirmed by plug in of heated vest to no power.
Any ideas what could be the problem (can't be connected to my heated grips wired into the spare connection behind the headlight?).
Any advice appreciated.
1050rat
ACC1 or ACC2 fuse is likely to be blown fella. Clock is different circuit.
In fact,i dont have an accesory socket built in like the newer 990's so it could be on the clock circuit after all.
Discussion Starter · #8 ·
The plugs on the back of those accessory sockets are a bit cheesy - might want to just check it hasnt vibrated off
Thanks mooky you were spot on took off the side panels this afternoon to find the plug hangin there.
We're green to go again !
1 - 9 of 9 Posts
