I get a smell of coolant when my 17 1290 Super AdvT (Non TFT display) is running, there is no coolant leeking onto the floor (paper put down to check), therefore i can only assume it is burning off the engine and or exhausts.
Coolant level is between low and high in the expansion bottle.
any and all advice is welcomed.
Find and check the vent pipe from the reservoir, I'm guessing it's near the foot pegs.
Does it look damp?
Check the radiator cap. I have heard that they can leak around where the 90 deg pipe fitting comes out from the plastic cap.
Does it look damp?
Thanks for the info, ill check those this evening and report back in.
You only need the smallest of leaks to smell the coolant whilst the engine is hot. Degreaser, very bright torch and or talc powder is the way to go.
HI Nigel, many thanks for your reponse, are you (or anyone) aware of possible common or known leak areas, as the engine area is fairly tight, and to avoid removing too much bodywork if I could focus in on specific areas that would be great.
Rgds David
Hi again. Mine was a really small weep on the top rad hose which hadn’t been pushed on far enough to the radiator stub, also I replaced the clip with a narrow band jubilee type. It was such a small weep that if it had been water dripping on the hot engine instead of coolant giving off a smell I would not have been aware of it, coolant level not a noticeable
drop In level.
Discussion Starter #8 (Edited)
I removed the tank, checked the rad cap, it could have been tighter, so i took it off put some Plumbers PTFE tape around the threads put the rad cap back on and tightened it well, checked all the hoses and jubalee clips, the were all good.
took the bike out twice over the weekend done about 500km's, and i still have the smell of coolant and it lost about 2.5cm (1Inch) of coolant from the expansion bottle.
Starting to get worried now?
Anyone else had this problem
