Due to lockdown, flooded tracks, and lockdown again, I've had a whole 1 hour on my new bike. It did feel like it's jetted a bit off, almost like it's a bit choked. It came with a load of jets and the owner said he used a Lectron carb. I assume he tried the jets and wasn't happy. What are you running, or suggest to run as a base?
I'm tempted to just change the top end now, but after that, how often are you changing/checking piston/rings (I know that's a "how long is a piece of string" based on how you ride etc)?
Piston kit wise, had no problems with Vertex, Wiesco and Mitaka over the years, but I know brands change in quality over time. What do you use?
