Any idea where you can buy the ABS rings with fewer teeth to prevent the errors?
KTM 690 enduro 2021. In previous models you could change it disconnecting a connector from the odometer, but it doesn't work in this model ( I didn't try it but everyone says the same)What year is your bike?
I haven't ride a lot, around 5km. I haven't got any ABS errors. I have 17" wheelsDo you ABS errors after riding a few miles with thec18" wheels?
Have you used ktm original Enduro 21 hub?. I used it with originals abs rings. Maybe the other kits doesn't use original parts.You should check it out, I have the errors and do many others. I will be intrigued if you don't get them?
Maybe I will have the problem when I ride more km. I understand that you had this problem, how do you fix it?.I have wheels from a 2016 SMCR.
It's not the hubs that is the issue, is the ECU is comparing the rotation of a 21" wheel and an 18" wheel. When you have two equal 17" wheels the ABS produces an error because its not seeing what it is expecting to see. It then causes an error and disables the ABS and theQuick Shifter.
