Hi All
I have a 1998 Duke 1 that needs some work doing on the engine. My sprag clutch failed so I bought a new one, dropped the oil and took off the right side crank case cover only to find the thread on the end of the crankshaft has been stripped so I can't get the clutch out to replace the sprag. Obviously my only choice is to get the crank re-threaded. It seems like a good time to uprate other "slow" engine parts and maybe get the cam changed and the head flowed etc. I know this engine is getting on a bit but does anyone know who may be able to do this work for me? I'm currently running full akra, 39mm fcr carb, k&m air filter and sas has been removed. Any help much appreciated.
