1 - 4 of 4 Posts
Hello, my apologies if I post this in the wrong section I'm new to the forum.
I've got a friend who rides a 2003 exc 200, he is after a donor engine or preferably just the right hand casing. After hunting around in all the usual places with no success I said I'd post the question on here for to see if any of you guys could help.
Many thanks
Rossi
Is it the right hand engine case (crankcase)? There's one on ebay just now from a 2002 200 which I'm pretty sure will fit (you'll need to check) for £70 or offers. The 125, 144 and 200s shared same crankcases up to 2012 when they changed a bit, but just not certain on 2002 year.
Sorry ktm808 I got that wrong it's actually the left hand can he needs, he could do with both but that is the side that is a complete write off.
Thanks for getting back to me, hopefully something crops up soon.
Ah, ok, Any LH case up to and including 2012 125/150/200 SX/EXC will fit. It's actually easier this side as you only need a rotor puller and an 8mm socket to swap the cases over. It pulls off easily by hand . Bob
1 - 4 of 4 Posts
