This is one for the guys who do all their own engine work.
Can I split the crank-cases while leaving the engine right hand side assembled?
Please note I have stripped and repaired engines for many years and don't need advice on engine stripping. This is simply to fix a leak between the 2 cases; I only need to renew the liquid gasket.
I am thinking I can remove the electrics and the oil suction pump to allow the cases to be split. Has anyone ever tried this and can give sensible comments?
Thanks in advance.
