Anyone know if a 2008-2012 headlight will fit a 2007 450 EXC?
I have a 2007 450 EXC and I'm in need of a new headlight. It works out cheaper to get a genuine 2008-2012 headlight and mask off ebay than a 2007 headlight by itself
Just need to know if it mounts up and if the wiring is the same or if modification is required
Fits straight on electrically and uses same straps but requires bottom edge shaping a bit unless you use the same era mudguard.
You have to trim the bottom corners as the fender angle is totally different. I have done it and it looks neat, but normally I swap the fender.
I tried it and you can see pics in my two rebuild threads. I think it not a great fit even after cutting so I bought a new shape front mudguard and that fits great and works with the new light. Pics of both in articles.
