1 - 4 of 4 Posts
I hope someone can assist here.
Trying to locate a service kit for the front brake master cylinder. KTM dont list one but I cant believe Brembo dont do one.
Does anyone have any part numbers of a service kit or at least the Brembo part number of the master cyclinder so I can search via the Brembo part number.
I would expect the service kit to contain the pushrod and a couple of seals similar to what I have obtained for my 450EXC.
Cheers.(y)
Email Venhill with details & pictures of your master cylinder showing any marking or part numbers, and they might be able to help you.
When mine went on my 1190 they didn't have a kit for it (they thought) but I persisted as it's just a Brembo MC, and after a few emails each way they realised they actually did do one, and it was in stock. I got it for good chunk less that what KTM wanted to charge.
Research has brought up the following if others require -
Front Master cylinder - Brembo OE part - part number # 10821081
Product description -
PSC12/25 Front Brake Master Cylinder - gold without reservoir w/lever.57 reg. polished - 10821081
Service kit for this - Brembo Part# 110279720
Master Cylinder Replacement Kit - 12mm Seal set
32953
1 - 4 of 4 Posts
