21 - 25 of 25 Posts
Weston beach race is coming soon!!!
What main you got in there now?
Think a 168 but it's a funny one as it's a 14 with what I was told is a 16 cylinder, head, and CDI. But the 16 jetting calls for something stupid like a 178 main. Also, the pipe is fucked and that is strangling the top end. Combine that with being wide open about 1% of the time makes it both a twat and a bit pointless to sort out.
Right... I fully stripped and cleaned the carb and moved the clip position as suggested, it has improved the hesitation but it was an absolute [email protected] to start the first time after putting it back together. Does needle position change how easy a bike will start? Done a cold start the following day and it fired up on the 3 kick but only without choke, have I cocked something up on reassembly?
Have you set/changed the air screw? You could have left it screwed all the way in after reassembly.
Assuming you won't have bent the float tangs when cleaning?
Or not even taking the advice and then moaning it still won’t work….
21 - 25 of 25 Posts
