Having trouble starting my bike using the electric start. When I press the start button the FI light comes on for about 1 second then goes off if I hold in the button. It comes back on again if I release and retry starting again.
I have a new battery, new earth cable, new contact washers(should a washer be on + one) new starter duke cable(+), new starter relay with new fuses, new starter cable, new electric starter motor, new spark plug.
There is spark and checked the connections. I am getting continuity from + to start button and too the electric starter motor. And checked the fuel there is still vapour coming out.
Could it be something with the valves? Has anybody had the same problem after changing so many things?
