Ho all,
I have recently got a 2005 Duke 2 640 and am looking at changing the headlight and Speedo for the 690 SMC R headlight and speedo.
Has anyone done this conversion before ??
If so any guides to carrying out ?
First issue is the duke 2 speedo being cam/cable fed where the SMC R is via a speed sensor.
Is there any aftermarket solutions that are compatible with the OEM speedo?
Any help would be great
Thanks Youngy, think will need to try and dig out wiring diagrams for each model to see way forward.
Hello Mikhall , I have a 2003 duke 2 640 that I picked up cheap with 1 owner very low miles , I am trying to do the same as you , I have brought everything apart from the speedo as I am stuck with this solution , I have been looking everywhere to see pics or what speedo to use , if you have or come across any information , please share . I will also do the same if I find any thing (y)
If I'm not mistaken the 690 smcr and 690 enduro 2012 used the same speedo. If so, the speedo is fed from a sensor mounted on the fork leg that picks up the frequency of the disc bolts passing by.
I have no idea if your dash has the same connection on the rear, I doubt it though.
Do you have an electronic pickup for the revs?
Actually... after thinking more....Considering the age of a 640, the 690 ecu setup is unlikely to have any compatibility with the newer dash...
The 640s a carbie no?
Hi Digi tech, yes will let you know how I get on thanks
