1 - 12 of 12 Posts
can anyone help please , the impelor failed on aride bike got roasting . turned it off, now wont start , good spark , just simply wont fire up , any help would be very appreciated
Could be, if it's got too hot. Check the clearance first before diving any deeper.
You could also use a compression gauge: plugs in where the spark plug goes, turn the engine over with the throttle open and see if its generating enough pressure.
So the next step is...have you got fuel? Is it getting through to the engine...ie is the plug wet after turning the engine over?
You could try a squirt of Easy Start to see if it fires/will run on that
Discussion Starter · #7 ·
no fuel coming out of injector , pump is working , f1 light says eng coolinant temp sensor ( 1long 2short blinks )
I suspect the bike's 'brain' has shut off the fuel to protect the engine from overheating damage.
It may need a dealer reset to 'clear the fault'...but you could try disconnecting the battery and leaving the bike for a few hours in the hope it forgets what happened to it.
Discussion Starter · #9 ·
disconnected battery , no f1 light now, still wont fire up , would a faulty eng temp sensor act as safety cut out ?
Yes, I'd leave it for a while, then go again.
You may need a KTM dealer or someone with a proprietary code reader to help you, but disconnecting the battery can sometimes work.
Discussion Starter · #12 ·
im going to take it to local bike shop to read the fault codes , will update as soon as i have info , thx
1 - 12 of 12 Posts
