390 top speed
1 reading
5K views 15 replies 6 participants last post by  Stevewilson
Hi all. I've recently bought a 2018 390 Duke. I have now done 1500 miles on it. It only had 200 miles on it when I bought it (dealer did first service as part of the deal) . I'm a bit disappointed with the top speed. What should I expect - standard bike. TIA
#4 ·
Is it just running out of puff, or hitting the limiter? Gearing can help.
I don't want to know the details, but your weight and size will be a massive factor. Put a 40kg person on the bike and it may make 100 for the KTM spec sheet... Also your riding kit - baggy clothing can slow it down, how you sit (upright or melted into the tank?) and then you are into the little things like humidity of the day, altitude, temp....
My Honda Dominator would do 85 if I rung its neck, and ideally a back wind to help... Just shows - it'd have never ever done 100 like Nords so I suspect I ate more pies...
Hi bigkuri. The bike runs out of puff. I am about 65kg, I haven't tucked in on the tank and I presume the gearing is stock.
Both wheels are turning freely so brakes aren't binding.
I had a Honda 400 twin in 1980 that would do 100mph+ (indicated). Surely with such a highly tuned up to date bike I should expect at least the same?
Yep, so the problem is worse than you think :rolleyes: ;)
There is always a 1290 out there with your name on it, that'll fix it... :D
I wish😍. I have checked the sprockets and they are std (15/45). Not sure where to go. I have read that the tappet clearances can change before the 4000 mile service - maybe that's part of the problem??
#12 ·
our stock duke 390 2016 did 160 (100mph for you lot) without much effort, sitting upright, fully dressed 100kg.
upto say 100kmph it was fairly "quick" after that it needed time to reach 160 from what I can recall.
it doesn't matter how heavy you are, it will reach the same speed with the same gearing just take a bit longer.
the bigger you are (or make) the more air resistance and then it has difficulty, true.
our 390 was on the dyno had 47hp and not so much torque, but all in the low end. the 390 (and 125 and 20 fro that matter) are short stoke engines an need to have their tits revved off for it actually do something. as the duke isn't really ment for top end speed, its a more a playful thing: quick acceleration and all that.
leads me to suspect the actual used cam timing is made as such; compare it with the 400LC4 for example, the older LC4 less hp but more torque and can also hit the 100mph if you are patient enough with the correct gearing.
