I've got a 2005 525 EXC and the guy I bought it from said that the previous owner had put stiffer fork springs and a stiffer rear shock spring on. I got what I think are the originals with the bike.
My question is what is the standard rear spring?
The 2005 parts list says it's the 80N/mm spring...
The 2005 Owner's Manual says 88N/mm for ALL rider weights (60-72kg, 68-82kg and 78-92kg)
One of them must be wrong.... which is it?? :confused:
80 is standard for 70 to 80kg rider, but its best to check the sag.
Cough Cough
That was a previous me ....Im much slimmer now and prefer a 100....Errr it is a new shaped bike tho' ;)
Thanks guys, that agrees with the fact I've got a spare 80N/mm spring!
With the 88N/mm spring, the static sag is ok (33mm), but the sag with me on it is right at the bottom of the range. I'll change the spring over when I can be bothered to change the fork springs and fork oil...
