Hello all. Would anyone know if head bearings for the Adventure would fit my 640 Duke ll 2007? I鈥檓 worrying I鈥檝e bought the wrong ones 馃拋
by the looks of it (online parts finder) it fits a whole range of bikes from 85 2T upto great white 1290 Super Adventure.
54201081000 is the old part nr from 2004 (no 2007 Duke II?), its replaced by 54201081100 same model range.
Discussion Starter · #4 ·
I also did a search of the part number but could only find this 54201081000 as the parts list only shows Adventure and gives me no option to pick 640 Duke 馃拋
The ad I鈥檝e seen says this if it helps - 鈥楽TEERING HEAD BEARING KIT FITS KTM ADVENTURE 640 1998-2007鈥
the LC4 frames are pretty much the same construction-wise from 1994 onwards. only real differences are there is or isn't an oil filter in the front downtube, space to remove the oil filter from the engine past the frame (bottom right side) and oil breather/filling plug on front downtube and some mounting points.
the part nr you provided is correct, however it has been superseded by the new part nr 54201081100.
so yes it should fit
