1 - 9 of 9 Posts
After the problems I had the other week with a totally fried battery.
I have now replaced the battery and the rec/reg (2nd hand off the bay)
Just been for a 5 minute ride, all was OK until I got home and the engine kept missing then would stall.
Any ideas please. :hmh:
Dave
does the bike fire up and run ok if ya let the bike sit for 10 mins if so it sould be the same prob i had and that was the coil was giving up it ghost journy times got smaller and smaller over time to a point were the bike would pop and stall about 5 mins after starting it
At the moment yes, just replaced the spark plug as well since I had a spare lying around.
I'll check the ignition coil late as the frame has just been powdercoated could it be screwing up the earth point there then?
But have you changed the plug CAP?
Mine had 3 caps on it in the 2 years I had it because of symptoms just like you describe.
The vibrations of the engine kills plug caps...
i had a prob when mine was powdwer coated.... i had to make sure that all earthing points were clear and good contacts, even the main frame to the sub frame
1 - 9 of 9 Posts
