Hi all,
Familiar problems with my 660, but this time a little bit different. It'll start first kick from cold with choke and first kick from hot. The issue is when it's been run for 2-3 minutes or so then cuts out and and has to be restarted - the bastard just won't go! I stood for 20 minutes trying to start it this morning after it cut out on the driveway, I eventually had no choice but to give up!
Has anyone else had this problem? Is there something obvious that I'm missing?
Thanks in advance.
I haven't tested the coil, thanks for the pointer. Will test it soon. Would a dodgy coil result in the problems I'm having? I'd have thought it wouldn't start at all if it was on its way out.
PPW
After you've checked out the coil. Have a think about the carb.
Your problem sounds a bit like mine that I've been struggling with for a long time.
I couldn't get a tick over and struggled to start it without the choke. I narrowed it down to the idle circuit in the carb. Still haven't got to the bottom of it but just fitted a new carb tonight and that fixed it.
I'll keep looking at the old carb and if I find something - you can try a swap over. Do you have an ultrasonic cleaner suitable for a carb at your work?
Not got much on just now (mine is running sweet and no real jobs outstanding just now:smokin:) so give me a shout if I can help.
Raymond
