i have a set of forks for a 690R enduro,09 model
what are they worth before i advertise them
thanks
loz
They are probably similar to the adv forks, no? They have quite long outer tubes (compared to dirt bike forks).
If theyre in good nick, Id ask 50% new price - you will eventually get it.
Both tubes are same as EXC.
He will have a long wait...
14187D11 Forks KTM 690 Enduro '08 £1188.40 for the pair.
People fit EXC forks to improve the off road capability and brand new EXC forks can be bought for £250 a pair.
KTM HUSABERG 48 MM OPEN CHAMBER WP FRONT FORKS SXS on eBay (end time 17-Sep-10 23:00:51 BST)
When you say both - you mean inner and outer?
Or you mean Adv and 690?
If theyre the same lengths as EXC forks, then yeah, value is much lower.
The 690Enduro forks are pretty much exactly same as EXC forks. Valving and springs are different of course.
OK, extended length of the cartridge is 50mm less, but the components are basically same, only 6 parts are different.
Like I say, people put EXC forks on to improve off road capability. I guess you could use 690 Enduro forks on an EXC supermoto conversion, but you would have to consider the different caliper mount as its Adv size.
