Hi Guys,
Any recommendations on a throttle cam for the 950 SMR?
There is far too much travel on the oem!
A mate reckons that the RC8 one will fit & is cheaper than the G2..?
Thanks in advance guys.
Have a look in the ADV section - theres a chap (markie_wales) selling a G2. Different cam profiles - but I imagine buying a cam is pretty cheap?
G2 throttle cam
I got one direct from G2 in the the States - I went for the faster opening one- a doddle to fit. Great mod for my 950 SMR, for a week after that I was laughing out loud every time I opened the throttle. :)
If you go fastest opener- i.e. opens the throttle alot for a small turn you will need to dremel some of the throttle housing away apparently.
I use the 050 G2 quick throttle on the road and it's a hoot.If you are unhappy about snatchy fuelling then don't bother.Probably suit the 950 because of smoother carb fuelling but for those who have sorted there 990's,it's a great mod.I use the 025 on the track which does require a smooth right hand in the tight stuff but still a lot of fun.Cheers.
