Defo. I use spray grease as its easier than using a tub. Putoline action fluid as filter oil (not the spray) and stale petrol as the cleaner. Never rotted a filter.
After petrol, use wash up liquid then rinse from inside out under a tap.
Dry filter, dunk in putoline, wring out, put in biscuit tin for next use. Best to have a couple on the go so you can clean bike and pop in a clean one.
I leave the action fluid in a biscuit tin as a bath - just dunk filter only when totally clean then filter oil stays clean.
Biscuit tin for filter oil, one for cleaning filter and then tin/s for storage. Sounds a faff, but being organised makes it easy and a stack of tins doesnt take up much room. I say 'tins' because mine are old, but a plastic 'celebrations' type tub will do the same job.
Been doing this for years.
