Yep another rear light post, I've read the others and can't find solution so here's the thing!
Front brake lever going to the bar. I simply topped up fluid in res and pumped it hard - let a little out through top. Then took forks to bits to swap springs over (legs off etc). Re-assembled those today started for test run and brake light permanently on. Checked connection behind light and by calliper and all seems fine. I didn't open the pads/Pistons at all when I slotted the rotor in (if that makes any difference) but it's really bugging me as I can't find the fault - it's a 2015 with 12.7 hours on the clock so not expecting any failures tbh - can anyone help please?
you've knocked the gigglepin holding the switch to the master cylinder....
Yeah, front switch has been knocked off the perch.
