I have been trying the famous NECJ needle in my 250RE Beta. It's worked in pretty much every bike I've had in the last 8-10 years but the 1st attempt on the 250RE is very lean. Zero spooge, steady tickover but half the plug porcelain circumference is almost white and the other very slightly brown. Bike running hot despite not going too fast.
Initial setup is 40 pilot, AS 1.5 turns out, NECJ clip 3 and 168 main. Exol 2T (is there any other?) @ 50:1, E5 fuel.
Fuel economy is usually around 10 miles per litre but this setup gave 14 per litre so it's way different.
The standard Beta needle was causing a spoogenami both out of the silencer and the PV breather pipe.
I have the following needles in stock and would be grateful to you jetting gurus for some guidance on the next one to try rather than buying a bunch of new needles just to find that they are no better
N8RG, N8RH, N8RG
NOZI, NOZJ (Beta standards)
N1EI
N84K
N2ZJ
Your help greatly appreciated. I have a weekend in Northumberland in a couple of weeks and don't want to cause problems whilst I'm away.
N8RG, N8RH, N8RG
N1EI
N84K
N2ZJ
