Hello,
My bike (2008 RC8) started running rough a few months ago so I pulled it apart for Winter to do a full service, valve clearances etc.
I didn't have TuneECU before so didn't get any fault codes but now that it is back together it is still running rough (possibly differently than before as can't ride it?)
P0638 code - 2nd Throttle control - system malfunction.
I had the TB's dismantled to clean the injectors (all OK) and it looked very logical to reinstall so I don't think I've done anything wrong. Throttle play adjusted and seems fine, (max TPS 95.4 but I understand that is normal), I cycled the 2nd butterflies using TuneECU.
TPS reading 0.591v which is between the 0.56 - 0.64v 'Zero' position and I didn't move the TPS anyway.
The map was 2009 Standard with o2 & SAI (it originally ran fine despite Jester exhaust & SAI removed) but I loaded the 2009 (all models) Akrapovic map with o2/SAI off then did the 15 min reset but no improvement.
Any ideas?
When I look at the rear 2nd butterfly it is closed and the front one is open when the bike is not running, is this normal?
I did a search but didn't find anything that helped.
Thanks,
Any ideas?
Thanks,
