1 - 3 of 3 Posts
its about time for a new set of rings since it has done about 30hrs on them its a 09 125 exc with a 144 kit on it wene i went to order some of jim aim site it said 08 144 or 09 150 so thinking 144 an 150 rings would be a diffrent size i got the 08 144 ones even though mynes a 09 bike but only 1 come an myn is a 2 ring piston are they the same should i just order another an put them in or buy the 09 150 ones
thanks guys
HI
The 2008 and 2009 model 150's are the same cc (144)
They both came with twin ring pistons. The 2008 and 2009 had different pistons and the rings are not interchangable (rings are a different shape)
I think that the 2008 piston + rings have been superceded and can't be bought anymore.
So if you have a 2008 piston you will need a new 2009 piston kit which is expensive.
Take the piston down to ktm shop and they should be able to give you the right rings as its due some.
I ususally change mine at 25hrs and new piston after 50 hrs.
Alex
thanks for that info alex just what i was after the piston has only recently been put in so it should be a 2009 piston i will get some rigs sorted tomoz i had my last piston in for 75hrs no probs still looked ok wene i took it out thanks again
1 - 3 of 3 Posts
