1 - 18 of 18 Posts
just cut up a tyre, with an angle grinder, now plastered in shit that doesn't come off
trying to make rubber washers, 'very large' to use to seal corrugated roofing sheets lol
should have used a tank cutter.......... perfect
wtf is a tank cutter
i thought that was a missile
A circular drill bit that cuts out a 'coupon', trade name is a 'starrett' cutter, any good tool supplier should do them. You may need the arbor to fit it to your drill. Depends what size you need the washer.
I might give it a try as have things like that for walls etc, for pipe work, cheers for the description
that'l be the bugger
So does the roof leak
6 years on
The guy is no longer with us, apparently a roof collapsed on him. :oops:
1 - 18 of 18 Posts
