1 - 3 of 3 Posts
bandit 1200, rear brake, suddenly pedal developed a lot of travel. Had a look at clipers, dust seals poking out, so rebuilt, then found the adjustable rod from master cylinder to pedal was bent, so replaced master cylinder with used one, put back together. pedal still has to much travel and fully adjusted up.
whats the most likley cuase (cant see any leaking fluid) ?
a mechanic says he bled the system and there's no air!
cheers all
1 - 3 of 3 Posts
