1 - 4 of 4 Posts
as title says the best damper money can buy. Under bar mounting
The whole kit costs
Damper on its own £403.09 ktm part number 58512050100
Stem £113
Fitting kit £50 EXC clamps
Easy turn adjustment knob £15
So over £550 worth
Item is brand new, i have only had it out of the box to eye it up to the bike to see how it fits and to take the photo it hasnt been used at all
£425
may take other ktm bits in px ;) WHY
Product info on the link
58512050100 - Gear 4 Direct
ktm sales blurb below
Close UpIt is the only Stabilizer with three fully adjustable circuits. It is the only Stabilizer that has an adjustable damping control that allows 25 adjustment clicks while riding. It is the only Stabilizer that allows you to adjust the amount of degrees of damping you want from centerline. It is the only Stabilizer that has a High Speed Circuit designed to absorb those sharp edged jolts. It is the only Stabilizer that successfully works for every type of off-road application... including Motocross. It is the only Stabilizer that easily moves from motorcycle to Motorcycle in literally seconds. It is the only stabilizer that's been around for 15 years and has won every major off-road race including the grueling Baja 1000, 15 times. It's the only stabilizer to be tested and endorsed by every leading off-road magazine Several times Rally Dakar Winner To complete your kit you will need to purchase the following additional items:- Steering Damper Stem Clamp 77012005344 Plus the relevant mounting kit to suit your triple clamp type. ie EXC clamps SX Clamps SXS Clamps SMR Clamps.
and fits like this
Please reply to your pm. thanks ;)
can you please resend, i had to delete a hundreds of pm's yesterday to get some normality back to the pm box.
Thanks,
Mark.
Done, thanks!
1 - 4 of 4 Posts
