1 - 9 of 9 Posts
The wrap-around style ones.
From the bolt hole to the top (middle).
(are they longer than the earlier EXC ones?)
Chairs.
345mm, about 10mm longer than earlier ones. Bigger diameter too, cos they use a moulded plastic upper tube protector.
I have a good used pair if you want a cheap set to play with :)
How much more of a PITA are they since you cant take them off the forks in situ?
I slit the back with a knife ;)
They are a pair to clean/ lubricate the forks, but I think the theory is they protect the fork lowers better from side impact. No good for SM front wheel, though cos they rub the tyre.
I have black ones and orange ones...... might even have a set I have not slit yet :)
If you dont want much for them, I'll take one of each. :)
Will look a bit weird, but it takes all sorts. Shall I send an orange left one and a black right one ;)
Sorry mate. Missed this post. (The way this forum works shits me to tears sometimes... :frown:)
I'll just take a pair of orange ones :)
1 - 9 of 9 Posts
