hi guys , i went out to matlock last weekend and found i was loosing pressure in my clutch lever! the clutch its self feels fine the bike torquie as hell its not slipping at all, so when i got home took the res cap off to find the fluid is black? Ive been using DOT fluid not sure if it is correct spec for the bike? anyway i cracked the bleed nipple off at the cylinder near the gear lever put on a pipe and put it in a tub a brake fluid and started to pump away i soon realized that the res on the clutch lever was not going down! so i locked off the bleed nipple on the master cylinder, and found i lost all pressure in the lever. so Ive tried to bleed the clutch lever up at the bleed nipple on the lever and the handle bars and i cant get any fluid up whats so ever
can anyone help please its pissing me right of at the moment:frown:
