1 - 4 of 4 Posts
Thinking of having rear tail unit and belly pan panels in carbon fibre.Has anyone had these and was the fit ok.I have heard some can be a pain to fit
If you buy from a reputable source and the panels are pre drilled you should be ok, original parts would have been used as a mould.
Check what experience the supplier has in carbon parts/reviews ect.
I have some carbon goodies fitted and more waiting to go on, the fit is perfect but they don't do the parts you want
Thanks for the reply only really found one company that does the parts im after Z4 motorsports.I have emailed them and they have said they may not be a perfect fit or some modification may be required.Only problem is they based in las vegas so if any problems it probably be a nightmare.
1 - 4 of 4 Posts
