1 - 20 of 30 Posts
Hello guys
Riding my bike today and someone pointed out that my chain was rubbing on my bike tyre which i hadn't noticed before. Was wondering what can I do for a bigger clearance but I was thinking it could be down to the tyre width?
just checked on the internet and apparently thats the correct size so could it be alignment issues?
Could be alignment or a fat tyre. Not all 160 tyres are the same installed width.
I'll check the alignment in the morning but if not do you think I should shave it?
Michelin pilot 3
oh, i read someone on SMJ had a similar problem with a dunlop tyre. some tyres do just have a different installed width as mentioned above.
i personally wouldnt be too happy with it rubbing, depending on how severe it is.
I know it's actually wearing the rivers on my chain. Do you think I can shave the tyre?
Discussion Starter #13
Discussion Starter #16
Also would suggest as other have done.. To check your alignment again, post chain tension adjustment..
I think I'll check It again in the morning then
You could move the rim across a bit by adjusting the spokes.
I did some measuring of tyres years ago....gives you an idea of just how much the installed width varies
Discussion Starter #18
Thanks for the chart. My wheels are magnesium aswell
i had a few different tyres on my 690 and they were never anywhere near the tyre?
just a thought, are the rear wheel spacers different for each side? could they have got mixed up at some point?
if not id say you have a problem somewhere, hopefully alignment, but it would have to be a fair way off?
1 - 20 of 30 Posts
