2004 model 950 Adventure.
Hi, please excuse such a basic question, but my sidelight and dipped headlight bulbs have both blown and I wondered if anyone has found a simple way to change them, or do I have to remove the fairing to get to them.
My brake light also appears to have blown, and I can't see an obvious way to remove the rear light lens to access it?
Any help or advice will be much appreciated.
All the best,
Keith.
working from memory,,, take the screen off and i cant remember if you have too loosen the side panels but its no great deal too do so ....and the rear lamp is bolted in from under the mudguard 2 x 8mm nuts............and check your charging if its over charging this will blow bulbs....about 14 volt is the norm
No need to take the screen off. Remove the top three side fairing bolts on both sides and slowly pull them away from the headlamp fairing - just enough to remove the fairing and screen as one item. Remember that the position light is on a separate loom.
