1 - 20 of 29 Posts
I would rather land on the oem ball shape than your sharp end ..unless you run wrap guards..but then what is the point to cut down the end?
Why? How does chopping the end do anything?
Lightnweight 馃檮
Not sure that鈥檇 pass scrutineering like that. Better to cut the ball off, drill out and araldite back on the stocker at the new required length.
Did you make any mechanical benefit changes to the pull? If not your one finger is not just working harder I reckon.
Get a Far East Engineering lever. That really is one finger and works tidy.
Discussion Starter · #8 ·
Stops the knurled edge hitting your middle finger during one finger operation 馃憤 I run EE wrap around so not too concerned about the safety aspect, its filed up nicely.
Discussion Starter · #10 ·
To be honest as a average joe sportsman my bike has never been checked over before racing, or maybe its one of those things that if it was spotted it would become a problem. Not what you want after forking out entry fee?
The trouble with the aftermarket shorty levers is they alter the clutch engagement point to much further in towards the bar so you have to work the clutch lever harder to get the same engagement as stock.
I guess I am just really fussy with the clutch lever much more than most. In technical riding I find it really annoying having to use 2 fingers on the clutch 馃槅
I generally only use one finger on the clutch and I use stockers... And I'm only interested in technical riding.
Discussion Starter · #12 ·
That's a solution to a non existent problem.
Come on, if it wasn't a problem would a whole host of aftermarket one finger clutch levers be available to buy? Perhaps you are not quite at the riding level where you realise its a problem? 馃槈 馃憤
After 40 odd years of riding and competition at all levels I've seen all kinds of cockeyed tweaks and "hot new ideas", I can assure you.
And I have learnt the difference between useful modifications and faffing about damaging perfectly good and expensive parts.
Having broken the two smallest fingers trapped between the lever and the bar when I hit a tree I can see the advantage. The wrap around handguard didn鈥檛 stay in position.
Don鈥檛 like the idea of no ball on the end though.
Moving the clutch perch further from the grip brings the finger nearer the lever end.
1 - 20 of 29 Posts
