It's another one of these...
Just had the Cylinder Head Nuts TSB done on my '04 950 Adv along with a coolant change and now have a bit of a problem. The bike was completely fine before
After a bit of "spirited" riding I park the bike up and turn the engine off - coolant spews from the coolant overflow, then the level shrinks back down and disappears or is very low (lower than min). When I started the journey the coolant level is ok - not above max..
After this I cleaned the rad cap and tried running the engine for a while without the rad cap on to see if air comes out..
When the engine was cold and revved a bit, the coolant level rose in the rad - if I'd kept reving it would spill over.. Is this supposed to happen - OR - Is this a cylinder head leak into the cooling system because there's a gap when it's cold?.... because....
When the engine was warm/hot and revved a bit, the coolant level dropped in the rad. Eh?
Hmm, by this time I can now see the coolant is getting damn hot and the coolant level in the rad starts bouncing up and down so I think, gotta turn the engine off..
I turn the engine off and whoosh - coolant shoots out the top of the rad and lots of it.. :wanker: I know :dozey:
Now do I take this bike back and say it's got a cylinder head leak? Whadya think?
