Cracked engine casing - repair?
4.7K views 9 replies 6 participants last post by  Pluto_
Has anyone cracked the engine casing on their 1290? What did you do? Did you use metal weld bonding glue or another method? How did it pan out?
I've been offered a otherwise decent bike with a repair that's lasted over 2 years for a suitably reasonable price.
#6 ·
There is a crank case (new) currently for sale on ebay however its a 2017 1290 Super Duke R. Its difficult seeing if it is the same item (same last 4 digits in the KTM catalogue) but could it have a different tolerance etc?! If it was the same it would save alot of money
#8 ·
Depends where the crack/damage is in the crankcase, if its held for two years without issue it doesn't sound like its in a critical area.
If you need to strip the engine down for welding repairs there is a good series on youtube (3 parts) so you can see whats involved time and parts wise. Although its about gearbox repair, the crankcase has to be split to get at the gearbox, you might need to do the same if welding repairs are required.
