I take it the subframe mounts under the seat both sides aren't supposed to have a crack running from the bolt hole to the end?
This is both sides
Also sidestand issues again :wanker:
After snapping in half the chocolate KTM (already repaired one) I fitted the one off my hybrid KX .
I should of known I was too fortunate when this happened.
It take it this a new part not a weld job?
should be plenty of bits about 2nd hand here and there, guess the subframe might be tricky/pricey to get hold of as folk like them to modify their pre '04 bikes sure someone will have something to get you fixed!
Jubilee clip round the ends of the subframe :cool: job done. As for the stand, thats crap luck mate, Im still on the original one (2001)
for sidestand think brokenlegs on here has some sort of superdooper fit n forget sidestand as for subframe remove and strip all parts from it take to alloy fab shop and they can weld it for u if you dont have one near to you then i think brokenlegs has a contact near him and when you refit it don't overtighten it
Thanks Golly. We have a tooled up fab shop at work,may have to flutter the old eyelashes!
Alternatively we deal with a good place in Towcester who'll fab and powder coat.
I'll just bung a bit of filler in for the MOT!
