Suspect with not using Van very little , should get a trickle charger.
Anyone know if this will work for the TPI (18) battery as well?
ta
s
MXS 5.0 doesn’t list lithium ion on the spec, I have a MXS 5 but I wouldn’t use it on a lithium-ion battery .
The C tek charger recommend is Lithium XS But not cheap,
I don’t find my lithium battery ever goes flat, unless it’s been flattened on cranking, but that’s never happened.
I got a Noco 3500 something, does both types of lithium and normal batteries too (the blurb is iffy, you have to look at several places to get the full lowdown)
Where you buy that from mate thinking about getting on for 790 r ? Thanks pal
My brother in law has a victron solar controller on his van, He really rates there quality
And it has a Bluetooth app to check charge status. So you would like to think the chargers are good as well
