1 - 2 of 2 Posts
Brake light working but not the tail light. Well after some time not running ( lost the driving license...) neither does the brake light work anymore! Any typical weak points to start with? Guess its not the led lights since the braking light worked earlier. Warranty case?
The wires that go in the tail light are soldered on a PCB that also holds the LEDs. The soldering brakes off, it is a common issue (had it my self but bike was out of warranty so i repaired it my self). They should replace it under warranty.
1 - 2 of 2 Posts
