1 - 20 of 28 Posts
I've taken all of the extras off of my bike and put it back to standard. I don't ride on the road too much any more so it'll probably be up for sale here soon.
Full stainless Swona exhaust system. The cans look very similar to this system. £250
Headlight mask/fairing in black, unused. SOLD
I've also got a Keihin FCR 41mm carb. £150
I'll add some more spares once I dig them out to remind myself what I have.
-Neil
I'll check tomorrow and confirm the exact details of the carb. My camera battery is flat so a pic might be tricky and the camera on my phone is terrible. I'll see what I can do though.
Got a few PMs about the carb. Nobody interested in the exhaust? It's a nice bit of kit and sounds brilliant!
Discussion Starter #15
Yeah, it's still for sale. If you refresh the page a few times (hold down Shift and click reload, that usually works best) then you should see the images. It's a DNS problem that I still need to sort.
Are the zorsts still up for grabs, and if so, could you provide some inlet measurements, cos I might be able to use 'em to track day the 950 sm. Dem akros dont like kissing tarmac.
Discussion Starter #20
The cans are still attached to the Y-pipe at the moment so couldn't measure those. The front pipes have a 30mm inner diameter and the outer ring looks to be 38mm (or so), I sure this is a standard fit so the specs should be available somewhere. I can measure the rest of the system for you if you need the details but I've run out of time this evening.
1 - 20 of 28 Posts
