1 - 10 of 10 Posts
Hi
I know my 12 plate rc8r should be E10 compatible but I don’t trust it regarding tank paint bubbles which I know has been reported on eg a superduke. My local garage doesn’t intend to get 98 RON E5 ( which by the way is 50 p more expensive a gallon!). Do others risk E10?
Happy biking!
I may be wrong but unless you have forced induction on an engine then you should not be using super unleaded - does this help?
I will run E10 in my SD990 and 1190 Adv but will drain the tanks for winter storage, just to limit the exposure on the tanks.
I agree that engines designed to run on 95 should not be asked to run on 98 as I think that will delay burning and lead to higher EGT.
KTM RC8
E10 in some older vehicles will corrode the fuel system, and perish rubber lines. E10 can also absorb more water than E5, so that can sit or build up at the bottom of carb float bowls, rust metal tanks, and make it hard to start after a while standing.
All KTM models post 2000 are E10 compatible. Not all KTMs require super unleaded, but all can run it.
E5 is generally now only going to be available in super unleaded form, this will not damage an engine designed to run on standard.
Higher compression RC8R engines have an ECU setting to take advantage of super.
Forced induction tuned ECUs with knock detection and timing control run better and more powerfully on super, because they can advance the spark to just below the point of detonation.
In short, run super unleaded in RC8R models with higher compression, if set in the ECU as per the manual, or if you're concerned about tank swelling with E10, or corrosion on aluminium parts. If you're planning on laying the bike up for a while, a full tank of super, or draining fully would be the way to go.
Otherwise if the bike is in use, fill with E10 as the fuel system was designed for it, other markets have higher ethanol ratios than E10.
I wont be using e10. If ktm's are supposed to be able to run ok on ethanol, why has ethanol fuel degraded fuel lines? The stuff seems to rot everything if its in there for more than a few weeks. ............. ethanol is a completd liability imo.
Boring repetition but luckily we can still get E0 std unleaded from a series of privately owned local garages.
Off to get three jerry cans full this week as it lasts for ages.
Reactions: Ship
My 2009 RC8 definitely doesn't like E10 so have to use Super 🙄
Do I need to change mode in ECU?
They just want to increase the cost of fuel and get rid of older vehicles 😒
Next year I might get my Superduke (990) re-remapped.
It's running rich I think. I always run with the exhaust baffle inserts in, and I'd like to do away with the power commander and instead have the map loaded straight into the ECU.
So.. this change in fuel type might be the excuse I've been looking for.
1 - 10 of 10 Posts
