1 - 3 of 3 Posts
After a top and front end rebuild, on the first green lane outing on Sunday my throttle stuck a bit. Nothing too drastic just a high tick over but on a tricky decent it made it a bit exciting. After a wiggle and accidently turning the fuel off it went back to normal . Has anyone got a photo of there bike with the tank off showing the routing? I have got 30mm risers but don't think that's the problem. Cheers Al
From memory.....From the throttle. Rider side of the bars. RHS of frame. Over tank bobbin on RHS frame. Through small rubber loop around the frame down to carb.
Check the inner cable isn’t worn/frayed in the area where it goes into the carb. I seem to wear throttle cables out just over a hundred hours. They go stiff from flattening the inner core from wear, then more wires break up. Then it snaps.
Hi I think it goes on the left hand side at the moment , I'll check tomorrow . Luckily, I've just filled the tank up :( Thanks
1 - 3 of 3 Posts
