enduro riding tips for beginners
1 reading
20K views 61 replies 37 participants last post by  knobby
As in title what are the most basic tips that you could give someone when enduro riding, could be in any situation hill climbs, rocks etc just something that once you tried, noticeably improved your riding
Any input grateful :D
#9 ·
All of the above. No-one is born a Jarvis.
1.Don't try to ride too fast, concentrate on balance and control, the speed is a natural progression.
2.As above bike time is better than anything else.
3.If someone comes past you, try and stick with them for as long as possible.
4.Look for grip, the most used line is not always the best.
5.Get your suspension set up and fit decent rubber.
6.Don't be frightened of 'giving it a go'. The worst is you will fall off.
7.If in doubt, ask, no question is a stupid question if you don't know the answer.
#13 ·
Ride ride ride the more you ride the more you'll condition your body and you'll relax, then technique finesse and speed will develop along with a better understanding of bike setup ... Simples
Reactions: fletche36
#17 ·
Make sure everything on the bike works properly - then it won't be distracting you. Especially the things on the bike you actually touch; there's nothing worse than riding a bike with a sticky throttle, stupidly heavy clutch or footrest that points towards the floor. That doesn't mean spend a fortune on bling, just have it all working the best it can.
Good tyres will mean they do their job without you having to worry constantly about sliding off.
The two big riding tips for me would be:
1. As many others have already said, look forward. This does two things; your balance is improved and obstacles/corners/hills/bogs/whatever aren't a surprise.
2. Something I've noticed with a lot of novice/not so good riders is they have an almost pathological fear of opening the throttle. Riding in to a steep uphill or a bog or a ditch with next to no throttle will only ever end up one way, stuck. Spinning wildly and getting over the top is so much better than gripping for a 1/3 of the way than toppling over or stalling. Obviously full gas on wet roots and rocks isn't good - so get the throttle open before you hit them, get some momentum and then back it off as the back wheel gets on the slippery bit. That means looking forward, to anticipate.
#25 ·
yeah if you want to finish events with flat tyres :D
ooops did I just open a can of mousse worms? :burnout:
