Being an idiot, I need an idiot's guide to do this, and I mean an idiot's guide, a true step by step dummy one.
If anyone has one please send it on . . .
Tell you how I did the blanking...
The carb blanks I used a 15mm section of a 4" nail, complete with head, smear with silicone and pushed in.
The holes in line with the carbs I used 20mm electrical blanking rubber grommets.
The fitting at the back of the airbox I filled with silicon.
The tiny pipe attached to the SAS valve I pushed a cut down 3" nail into.
The front blanking plate is a swine to get to on the Adv, so I cut the original hose near the tee that goes under the airbox and put a short piece of 12mm dia steel rod in there, secured with a jubilee clip. Next oil change the oil tank can be moved a little to allow access to both screws.
edit
