1 - 9 of 9 Posts
Last week I changed the front sprocket, put some loctite on the screw and tightened it with 60NMs.
Yesterday after I washed the bike I found that I can turn the washer with two fingers although the screw is still tightened :eek:
Whats wrong?
Cheers, Steve
The washer is supposed to be dished shaped. Has yours flattened?
(tightwad that I am!) I redished mine by putting it in a large socket and belting it with the ball end of a large hammer.
*lol* nope, it's still in its original shape...
Sprocket on back to front? Smooth side is sposed to be out, side with the lumps on goes against the engine.
Ouch! Are you sure? Cant remember how I put it in... how's the washer to be installed. I fixed it with its concave side outwards....
Had this same issue on my 525 a month ago....a new washer/bolt from my local dealer sorted it out.
I can only assume the washer gets slightly flatter with age, still looked the right shape but didnt quite grip properly.
OK... mh. Lets see, I was -what rarely happens - totaly caned the night before and when I was replacing the sprocket I was still cross eyed *lol* And after 2,7 hours of use the darn washer should be like new.... Let you know what I found...
thank you guys. me idiot has installed the sprocket wrong way round. everything is fine now. no I will not touch the bike again when I am still bladdered :) promise.
1 - 9 of 9 Posts
