1 - 4 of 4 Posts
Once more for us dummies, to set the oil level in an '09 250 EXC (or similar) it is:
Spring out, fork outer fully compressed, damper rod fully compressed?
Also I remembered reading somewhere that 120mm was the right level, but manual says 110mm, which one's right?
110 would be to hard with standard springs
120 with standard springs is about right for most average riders
130 if you are slow or want very soft suspension will poss bottom on some tracks and are sportsman
alot of variables like spring pre load rider weight shim stack
stick with 120 you can always add or take away some
1 - 4 of 4 Posts
